Creates an RSVP-TE routed path resource.
| path_name | Identifies the path within the switch. The character string must begin with an alphabetic character, and may contain up to 31 additional alphanumeric characters. |
N/A.
This command creates an RSVP-TE path resource.
The path_name parameter must begin with an alphabetical character and may contain alphanumeric characters and underscores (_), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For name creation guidelines and a list of reserved names, see Object Names in the Switch Engine v33.1.1 User Guide .
The maximum number of configurable paths is 255.
The RSVP-TE LSP is not signaled along the path until an LSP is created and then configured with the specified path_name.The following example creates an RSVP-TE path:
create mpls rsvp-te path path598
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
